NX API forums breakdown
I'm still trying to get familiar with the community forum layout.
My suggestion is for the NX's API, break them down to at least five individual subjects, such as...
GRIP
UFUNC/C
Unmanaged C++
Managed C++, VB .Net, SNAP, C#, Java
KBE - Knowledge Fusion (Designer & User Classes Design)
Similar to the programming help documents.
Maybe this exists currently and I just have not discovered it.
edit:
With regards to the GTAC Customer Forums Archive (Read-Only) - KBE section.  Within the Search field, it eliminates underscores such as; "ug_datum_plane" is changed to "ug datum plane".  Including the underscores in the search key phase would help narrow the search results.  I tried the advance search and get the same result.
Thanks.
