Reassign or change a dimension of a line
I'm having problems drawing small parts in the range of 2 to 5 inches and fitting it to the drawing page where a person can see and read it. Also I need to be able to draw a part to an exact dimension i.e.. " 3.478 " .  Can the grid be changed to a different dimension so my drawing are seeable .
Re: Reassign or change a dimension of a line
Community Admin Community Admin
Community Admin
hi michaelC -
You posted this in the Community Suggestion board. If you let me know which software you are asking about, I will move this topic to the correct area. When we move it, you will most likely get a lot of responses.
Susan
If you find my post helpful, and it answers your question, please mark it as an "Accepted Solution"
Try Solid Edge for free
