Alert based on Threshold in Mind Connect or Asset Manager
I need some help to understand how to generate real time alerts on incoming data from device using threshold in MindConnect.
Is it possible to do this on Cloud side in Mindsphere.
Any help is appreciated.
3 REPLIES 3
Re: Alert based on Threshold in Mind Connect or Asset Manager
Siemens Genius Siemens Genius
Siemens Genius
You can consider 3 possible solutions.
1) Using Data Flow Engine (DFE), TimeSeriesSource, FilterProcessor to define the threshold and EventSink to trigger events.
2) Using Visual Flow Creator (VFC) - Create a logic to check the asset's incoming data against the threshold value and trigger and event.
3) Using the Fleet Manager Rules - Using the fleet manager rules. you can define the threshold value to check and generate events accordingly.
You can then view the events from Fleet Manager -> Events
Thanks for the answer Sriram. One more thing I am just doing a POC as of now but to use fleet manager for rules and alert Siemens is asking for subscription that is too expensive. What would you suggest in this scenario?
Siemens Genius
You can consider Data Flow Engine (DFE).
