Re: Calling the API with cron job
You have an example on how to access the mdsp core services via a script in the devops-demo project, it's gitlab-ci in there but cron would be the same process:
https://gitlab.com/mindsphere/devops-demo/blob/master/.gitlab-ci.yml#L109
https://developer.mindsphere.io/howto/howto-selfhosted-api-access.html
If you want to access the api offered by one of your backend services, that is currently not officially supported as far as I know. Subscribe to the thread below to get updates on that:
https://community.plm.automation.siemens.com/t5/Developer-Space/Calling-backend-service-from-the-out...
@dvidflrmnd  i do have technical user with me. but i don't really understand how i can set cron job using this technical user.
i wanted to run some task at 8.30 AM every day & some on every 15 min interval. so how i can do this?
