Can MindApp call an External API?
Yesterday I got a question from a potential partner.
He want to know wether it is possible to call an external API. Reason behind is that not all required analytical functionality is available through the MindShere API. Is it possible to call an API outside MindsSphere and incorporate the functionalyty in a MindApp?
Re: Can MindApp call an External API?
Yes, it is technically possible to call external APIs, however its not allowed by the development guidelines and for publishing an app. Everything should work through the MindGate / MindSphere Gateway. In the development guidelines that you will need to accept and sign as a developer is stated ""Your Application must not call any APIs outside the Platform."
