Change the color of the MindSphere OS Bar
Dear All,
we are currently developping two common themes (light and dark) for MindSpere and Non-MindSpehre apps.
In order to fit the MindSpere OS Bar best in our themes it would be helpful to adapt its color. Is this possible?
Thanks in advance.
3 REPLIES 3
Re: Change the color of the MindSphere OS Bar
As of now it is not possible to change the color of the MindSphere OS bar (refering to OS Bar v4).  It always appears in the dark theme.
Information about the OS Bar functionalities and options can always be found here.
The color can be hacked with help of javascript. However, this will most probably prevent the application from publishing to operator tenant
document.getElementById("_mdspbar").style.backgroundColor=" #2B3856"
This way of overriding the styles manually is not recommended in any way and - in addition to risk not getting published - might change or break anytime.
