How do debug a mindsphere a mendix mindsphere app locally
have developed my first mindsphere app with mendix. The actual version is really basic, with some input boxes. I have pushed the app via cloud foundry and is accessable from the mindsphere launchpad. Now I want to make the the next step, accesing the data via the timeseries api. I have assigned two users and following core roles:
  • mdsp:core:iot.timUser
  • mdsp:core:assetmanagement.standarduser
For the pushed app I have although created a app credential with read/write access. But on every startup I got a timeout for the access.
I am running the development enviroment locally and the project data is also stored locally. Is a client credential necessary for local testing?
Re: How do debug a mindsphere a mendix mindsphere app locally
Hi Ingo,
to make calls to the MindSphere localy you need the app credentials.
With this app credenials the SSO module will go and ask for a valid MindSphereToken.
When making a REST call to MindSphere make sure that this call is always authorized with the MindSphere Token.
All details you can find here https://docs.mendix.com/refguide/mindsphere/mindsphere-development-considerations#1-introduction.
For local development please consider that you maybe need special proxy settings to get out of your company network.
Yes, the proxy settings can be set in mendix studio.
https://docs.mendix.com/refguide/custom-settings#10-proxy-settings
