How to recover/retrieve the organization name
We have a developer account, and it's been a year since we deployed our sample application to the Cloudfoundry/mindsphere. The org name that we used last time does not seem to work now, can you tell me the procedure to recover/recreate the organization name and space to deploy the application?.
We are not able to add the org name that we used earlier
Organization 'XYZ' not found.
FAILED
Re: How to recover/retrieve the organization name
I'd contact MindSphere support directly for issues such as this.
Siemens Genius Siemens Genius
Siemens Genius
@svn yes I would suggest the same and send this to us here at Support.  We would need to verify V2/V3 and that would allow us to help you better.  Typically the org name is the same as your tenant ID, but you might be asking about V2, in which case there's a much different answer.
