IoT Time Series Service API returns "403 Forbidden" Error
Hello. I have a question about using "IoT Time Series Service" API because it does not work ordinalily.
Before start, my purpose is getting simulation datas from "MindConnect IoT Extension".
and insert datas to user-defined apps
First, I referenced  "https://documentation.mindsphere.io/resources/html/mindconnect-iot-extension-gs/en-US/115404857227.h...and created simulation datas.
Next, to check simulation datas, I used  "Read Time Series Data" from "IoT Time Series Service" API
https://developer.mindsphere.io/apis/iot-iottimeseries/api-iottimeseries-samples.html
https://gateway.{region}-{environment}.mindsphere.io/api/iottimeseries/v3/timeseries/{assetId}/{aspectName}
But,  it returned "Access Denied". In Postman, it was "403 Forbidden" error.
Why 403 error is happend?
Is there problems about roles and scope?
Please help this problem.
Re: IoT Time Series Service API returns "403 Forbidden" Error
That means you're not providing the required authentication headers. If you want to access the APIs from Postman, you can use the flow for self-hosted applications:
https://developer.mindsphere.io/howto/howto-selfhosted-api-access.html
Alternatively, you can "steal" the session cookie from a browser and use it in your call:
https://gitlab.com/mindsphere/devops-demo/#local-development
