MQTT Connection Error
Hi, guys. I am setting up MQTT client in MQTTBox following this instruction.
https://developer.mindsphere.io/howto/howto-mqtt-mciot.html
But keep getting Connection Error, attached is my MQTT Client Setting. What might be wrong in my settings?
Re: MQTT Connection Error
Siemens Genius Siemens Genius
Siemens Genius
@Martin-Lee assuming you are using eu1 region, the host URL should be
mciotextension.eu1.mindsphere.io
Also, please make sure that port 1883 is not blocked by your firewall.
