MindConnect Nano Throughput
Hi everyone,
I have read about Nano is its data reading cycle is 250 data points per seconds. Does it mean it can read 250 data point points (pressure, temp) or data values? What I am interested in how much data it can read in a second and how much it can transfer to Mindsphere? What I know It transfers data every 10 seconds.
Thanks in advance!
Divya Garg
3 REPLIES 3
Re: MindConnect Nano Throughput
Hi @divgcet
From what I understand the 250 data points / second is just a reference, not a hard limit. i.e. It should be able to do higher than 250 if it is booleans/integers but not for strings.
The real throttle I think is the upload of once per 10 seconds and... this might be wrong but from memory: 1 mb per upload.
Thanks for the update @Rex_Chen
According to you, I take the throughput as 1 MB upload per 10 seconds tentatively.
Will be appreciated if anyone else can give more a better picture.
Thanks and regards,
Divya Garg
