MindSphere Gateway error 403 forbiden
https://htywms18.eu1.mindsphere.io/api/iottimeseries/v3/timeseries/8390768cb4c8453ca24c99e10dd880eb/... =8390768cb4c8453ca24c99e10dd880eb&propertysetname=testCollection&timeseries =[{ "_time": "2018-11-02T00:00:00.001Z", "quantity_elec": 30, "electric": 200, "notes": "normal operation" },{ "_time": "2018-11-02T00:01:00.001Z", "quantity_elec": 30, "electric": 200, "notes": "normal operation" }]
This is my request path.I want to know what's wrong with my path,and what else parameters needed.who can give me a success demo.How can I get other parameters?thanks.
3 REPLIES 3
Re: MindSphere Gateway error 403 forbiden
You are trying to access mindsphere with postman and you are not providing the required authentication headers, please check:
https://developer.mindsphere.io/concepts/concept-authentication.html#calling-apis-from-frontend
Take also a look at the link below, you can use the same technique to call the APIs using Postman:
https://gitlab.com/mindsphere/devops-demo/#local-development
I don't know how to get the authentication.I try to get the token throw this path "https://gateway.eu1.mindsphere.io/api/technicaltokenmanager/v3/oauth/token" ,but it didn't work.I also try this path "An Authentication object was not found in the SecurityContext",and it throw the error "An Authentication object was not found in the SecurityContext".
"MindSphere Gateway error: Invalid CSRF Token 'null' was found on the request parameter '_csrf' or header 'X-XSRF-TOKEN'."
what's the meaning of '_csrf' or header 'X-XSRF-TOKEN' ,and how can I get it.
