MindSphere Gateway error: A redirect is required to get the users approval
I'm just in the development of an App in MindSphere.
I this application I link to a external WebSite.  In the content-security-policy  I added the url and it worked fine.
But now I'm getting the Message: MindSphere Gateway error: A redirect is required to get the users approval
What did MindSphere change and what to I have to do, that my application will run again.
Any ideas?
  Eric
9 REPLIES 9
Re: MindSphere Gateway error: A redirect is required to get the users approval
Does this problem still exists? In this case contact support with this information.
a strange behavior. The error disappears after about 30 minutes. But turned up again after each new registration and then disappeared again.
Sounds like a caching issue in the registry. Just open a support ticket.
I'm just experiencing right now the same thing. I guess I'll wait 30 minutes...
Hoping 30 min wait is all I need to get my application running. Smiley Happy
I am hitting this issue too.
Does it really go away after a certain time or did you do something specific?
Turns out deleting the cookies for the domain of the app solved the issue for me.
Annoying issue nevertheless.
The problem I was facing was because of Memory requirement. So I scaled my application with 1GB memory and since then its woring perfectly for me. Smiley Happy
Deleting cookies works for me as well. Thanks. It's really annoying, poor information and not friendly message...
