MindSphere OAuth authentication
As descriped in the MindAccess developer tutorial document MindSphere provides OAuth Authorization Server to acquire an access token.
We have tried the following POST request:
curl -X POST \
https://minddfi-st1.3rdp-iam.mindsphere.io/oauth/token \
-H 'accept: application/json' \
-H 'authorization: Basic bW...............................' \
-H 'content-type: application/x-www-form-urlencoded' \
-d grant_type=client_credentials
...but the response is always "{
"error": "unauthorized",
"error_description": "Bad credentials"
Should this be possible with normal tenant admin rights? Is the zoneid = tenant name?
Re: MindSphere OAuth authentication
If you are in a development account you need to use the dev endpoint for iam (3rdp-iamdev) so from your example:
https://minddfi-st1.3rdp-iamdev.mindsphere.io/oauth/token
You may also have to switch to an http GET passing the grant_type in the url parameters:
https://<tenant-id>.3rdp-iamdev.mindsphere.io/oauth/token?grant_type=client_credentials
Hey Miikka,
can you tell me where you got the "MindAccess developer tutorial document" from, you refer to?
Greets
Tom_
