MindSphere UI APP gets 302 ( redirect response).
I am running into an issue with my MindApp . It has a reactJs front end and java backend. When I do REST call to from ReactJS to my backend , I get 302 ( redirect) response and redirect url is the login url ( https://<app_name>.eu1.mindsphere.io/login).
The backend app java security is disabled and the REST API call (GET) works from a browser tab, but not from App (reactjs).
I came across Pivotal Cloud foundry articke talking about same issue ( https://community.pivotal.io/s/article/spring-boot-app-keeps-returning-http-status-code-302)
Any clues/experience in this regard will help.
thanks
Re: MindSphere UI APP gets 302 ( redirect response).
Might it be that you are not correctly setting the XSRF protection token?
https://developer.mindsphere.io/concepts/concept-authentication.html#calling-apis-from-frontend
