Mindconnect IoT Extension: How to monitor the connection status of device created using mqtt
I followed the tutorial https://cumulocity.com/guides/device-sdk/mqtt/#hello-mqtt-python to create a device in IoT extension and send measurement data from it.
I am successfully receiving the data in the Measurement tab of the device. But the connection status is coming as 'not monitored' or 'inactive' at all times.
How do I configure my MQTT code to change/monitor the connection status of my device?
Thanks.
Sonali Jain
Re: Mindconnect IoT Extension: How to monitor the connection status of device created using mqtt
Siemens Genius Siemens Genius
Siemens Genius
@SonaliJain, you can set the required interval for availability monitoring using smartREST 117 command.
Example:
117,30
