a month ago
Hi.
My questions is actually pretty simple:
When I upload an application to Mindsphere which needs to access Mindsphere APIs (for example, time series), I have to methods to authenticate this APIs calls:
The problem is, what if I have an application that has no frontend? I mean, I upload an application to Cloud Foundry which needs to make use of the APIs and also cant be tenant specific. The application needs to read and write timeseries continuously. Is this possible?
Thanks in advance!
Solved! Go to Solution.
a month ago
a month ago
If I provide the service credentials to the application, then I need to customize the application for each tenant, because service credentials are tenant-dependent.
a month ago
a month ago
a month ago - last edited 4 weeks ago
FedericoPeccia, I think the Token Management API that dlouzan mentioned sounds like it will work for what you want.
4 weeks ago
