Not able to deploy python flask application
I am getting below response while cf push  python flask application in mindshpere.
2019-07-04T18:45:47.45+0530 [APP/PROC/WEB/0] OUT * Serving Flask app "fftProcessor_mindsphere.py"
2019-07-04T18:45:47.45+0530 [APP/PROC/WEB/0] OUT * Environment: production
2019-07-04T18:45:47.45+0530 [APP/PROC/WEB/0] OUT WARNING: This is a development server. Do not use it in a production deployment.
2019-07-04T18:45:47.45+0530 [APP/PROC/WEB/0] OUT Use a production WSGI server instead.
2019-07-04T18:45:47.45+0530 [APP/PROC/WEB/0] OUT * Debug mode: off
2019-07-04T18:45:49.46+0530 [APP/PROC/WEB/0] ERR * Running on http://127.0.0.1:5000/ (Press CTRL+C to quit)
2019-07-04T18:46:47.25+0530 [CELL/0] ERR Failed to make TCP connection to port 8080: connection refused
2019-07-04T18:46:47.25+0530 [CELL/0] ERR Timed out after 1m0s: health check never passed.
2019-07-04T18:46:47.28+0530 [APP/PROC/WEB/0] OUT Exit status 143
2019-07-04T18:46:47.41+0530 [CELL/0] OUT Cell 73fefc51-267e-4680-bb25-9567baa79693 stopping instance 390d58f2-2523-4574-4e90-5be6
2019-07-04T18:46:47.41+0530 [CELL/0] OUT Cell 73fefc51-267e-4680-bb25-9567baa79693 destroying container for instance 390d58f2-2523-4574-4e90-5be6
2019-07-04T18:46:48.34+0530 [CELL/0] OUT Cell 73fefc51-267e-4680-bb25-9567baa79693 successfully destroyed container for instance 390d58f2-2523-4574-4e90-5be6
Re: Not able to deploy python flask application
CloudFoundry is killing your container because it's not able to reach the health endpoint that you must expose. Just check the linked docs:
https://developer.mindsphere.io/concepts/concept-cloudfoundry-apps.html#monitoring
Exactly as dlouzan mentioned.
The problem might be that you are trying to run a debug server with the port pre-defined on Cloud Foundry. Try running the server like below:
#test if env is in cloud foundry by getting VCAP port
try:
    port = int(os.getenv("PORT"))
except:
    if __name__ == "__main__":
        #appEnv = "debug mode"
        app.run(debug='true')
    #appEnv = "Cloud Foundry"
    app.run(host='0.0.0.0', port=port)
