What is qualitycode field in IoT Time Series API
The IoT Time Series service documentation says, "In the aspect type definition, there is a qualitycode field, which indicates whether quality code data will accompany the time series data. "
What exactly is this qualitycode field? what does it signify?
Thanks.
Re: What is qualitycode field in IoT Time Series API
The quality code is a functionality that you can enable for your aspect definitions that allows you to upload a quality control code for each data point delivered to MindSphere, and distinguish cases where you had connectivity issues when sending IoT data.
See below for more information:
https://documentation.mindsphere.io/resources/html/getting-connected/en-US/122724635531.html
https://developer.mindsphere.io/apis/iot-iottimeseries/api-iottimeseries-overview.html#basics
