cf CLI Login not working from Intranet
After setting a proxy I still recieve a connection error when trying to login to the Cloud Foundry interface for MindSphere on AWS.
Below is the response from the cf login attempt:
cf login -a https://api.cf.eu1.mindsphere.io
API endpoint: https://api.cf.eu1.mindsphere.io
FAILED
Error performing request: Get https://api.cf.eu1.mindsphere.io/v2/info: proxyconnect tcp: read tcp 157.163.1.200:20990->194.145.60.1:9400: wsarecv: An existing connection was forcibly closed by the remote host.
For reference here are my proxy settings:
set https_proxy=https://194.145.60.1:9400
set http_proxy=http://194.145.60.1:9400
npm config set https-proxy http://194.145.60.1:9400
Any ideas on how to solve this issue are welcome.
Re: cf CLI Login not working from Intranet
You may have a typo here. Looks like you have set the proxy differently on both NPM and in the environment variables (underlined below)...
Try the following...
set https_proxy=http://194.145.60.1:9400
This works perfectly!
Much appreciated!
Please accept it as a solution, so that everyone knows that the issue is solved.
