cloud foundry microservices deployment
Hi all,
I have sucessfully deployed an application (angular+springboot) into mindsphere. now i need to seperate them into microservices. (app, API, Business Logic, etc..) I wanna findout followings
1. Is it possible to deploy microservices in mindsphere cloud foundry. If yes, please send a documentation link
2. Do siemens recommends this approach.
3. How does the pricing model effects
4. Any Other implications
Thanks in advance.
Re: cloud foundry microservices deployment
From your question I'm not exactly sure how you have structured and deployed your app at the moment. I have shared some ideas and links below which hopefully might help you.
You can create one app (one source code repository) which contains multiple components (eg a frontend, backend data service, analytics engine etc). Using one manifest.yml in the route of the app folder you can deploy each of these components in a single cf push. Each components can use a different buildpack if you wish.
Links to support this...
MindSphere recommended appraoch...
https://developer.mindsphere.io/concepts/concept-cloudfoundry-apps.html
How to use a single manifest file for multiple components...
https://developer.mindsphere.io/howto/howto-cf-single-manifest.html
12 factors also as a guiding principle in many areas but with regards the above particularly factor 1...
https://12factor.net/
@Rob_M, i found link  helpful to solve this query.
I tried to call external web api through my ui (configured csp - connect-src as well). it seems like its not allowed. (link confirms it) is my understanding correct?
