mindconnect api
I am trying to connect my iot2040 to mindsphere using the mindconnect cli. I am trying to offboard my agent that is already onboarded. But it asks for a passkey. I need a passkey to get service token as well. I don't know where or how to get this passkey.
3 REPLIES 3
Re: mindconnect api
1) Please refer to documentation
https://opensource.mindsphere.io/docs/mindconnect-nodejs/cli/setting-up-the-cli.html
"You will have to create and remember a passkey at this moment which must be used in other CLI commands to unlock the credential store."
2) Alternatively, you can use Asset Manager UI to offboard an agent. The steps mentioned in attached file
Re: mindconnect api
Thanks Vaibhav,
So  tried getting service credentials using mc sc --username --password --tenant --passkey according to the help section.
I got an error saying:
EACCES: permission denied, open '/home/user/.mc/auth.json'.
Is there something that must be present in auth.json?
I just wanted to clarify I have an agent that does not have a pre-installed mindconnect library and I had to install the mindconnect cli to it.
Let me know if you need any additional information.
Re: mindconnect api
It was an elevation issue. I got the service credentials and created a passkey! Thank you so much!
