mindconnect-nodejs : Network Error unable to upload data using starter-js project
Trying to user starter-js project after setup when I run index.js I am getting this error message .
[2019-07-21T17:17:36.892Z] Iteration : 0
Error: Network error occured request to https://southgate.eu2-rc.mindsphere.io/api/agentmanagement/v3/oauth/token failed, reason: connect ETIMEDOUT 13.95.129.43:443 (hint: possible cause for this error is invalid date/time on the device)
at MindConnectAgent.<anonymous> (D:\hack\starterts\starterjs\node_modules\@mindconnect\mindconnect-nodejs\dist\src\api\agent-auth.js:253:23)
at Generator.throw (<anonymous>)
at rejected (D:\hack\starterts\starterjs\node_modules\@mindconnect\mindconnect-nodejs\dist\src\api\agent-auth.js:5:65)
at <anonymous>
at process._tickCallback (internal/process/next_tick.js:188:7)
Re: mindconnect-nodejs : Network Error unable to upload data using starter-js project
@SunilPrasad , did you already check this?
"hint: possible cause for this error is invalid date/time on the device"
@darthsn0wcat do you know more?
The client can’t establish the connection to MindSphere. Please verify that your proxy settings are set correctly.
https://opensource.mindsphere.io/docs/node-red-contrib-mindconnect/getting-started.html#tab1anchor7
