predictive learning mind apps
I was analyzing the predictive learning mindapps and found that I can put custom models in the workbench.
If I need to access data from timeseries against an asset so
a) Is timeseries REST API only the way to access it?
b) can it be accessed on socket using some client library of cassandra of mongo db whichever storage is used.
Accessing it on socket will be much faster otherwise loading of data itself will take lot of time for any custom job.
Prashant
