2d sketch programming
Hello all,
Can i generate a program using 2D sketch and if it is possible we have to define blank and how can we do that and what all parameters required? Can anyone help me.
Lets say i have a  rectangular sketch and inside the rectangle i have drawn two small rectangles and for that i have to create a programme.How can i achieve this!!
Any Sugestions
Re: 2d sketch programming
Yes, use PLANAR MILL operation for that:
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help#uid:xid1128418:index_mfgmillingSmiley Tonguelanar_...Smiley Tongue
Marek Pawlus, NCmatic
Production: NX 12.0.1
Development: C#, Tcl/Tk, CSE
Thanks @Marek_Pawlus Smiley Happy
Hello ive tried to follow the steps but as per steps given im not able to see material group under mill bind part boundaries dialogue box and ive have drawn a 2d sketch can u help me with this??1.JPG2.JPG
Here you are:
https://youtu.be/e1qxR17yTUY
You have "Tool Side" option on a picture which you attached. This should do similar job as "Material Side", just with opposite meaning.
Unable to play video. Please try again later.
(view in My Videos)
Thanks mate yes it is exactly where i'm rite now and the thing is  whenver after sepcifying the blank and go to verify the tool path i'm getting as  blank not specified but i have spcified can u  tell me where i might be going wrong here is the video attached from my work
Hey mate ..it worked 😊thanks a lot for ur suggestion.
