3+2 without 5 axis license
As the title suggests I have the 3axis milling license but I was wondering if I could do basic 3+2 axis machining with this license. Currently I don't need to do any simultaneous 5 axis operations so I don't need that functionality but it seems like I could do basic 3+2 axis work with my current license. Could anybody verify this for me?
Thanks.
Re: 3+2 without 5 axis license
Hi
You are correct. For NX licensing 3+2 milling operations are the same as 3 axis.
you can change "tool axis" option in every 3 axis operation.
Marek Pawlus, NCmatic
Production: NX 12.0.1
Development: C#, Tcl/Tk, CSE
That's exactly what I thought. Might be time for a new purchase! Thanks again Marek.
By the way, the reference set things we discussed in our email worked perfectly once I understood how to use it.
Thanks again!
