3D Profile Multiple Lines
Builder
Builder
Good day,
Need help to create tool path on multiple lines using 3D profile operation by selecting all lines at once.
Please see the attached image.
3 REPLIES 3
Re: 3D Profile Multiple Lines
maybe use fixed contour, curve/point method, make multiple sets of curves,  and offset tool left on curves in method
Builder
Builder
Good day,
Thanks Juraj to your reply, I have tried your suggestion but the result is different from what I am expecting.
I want the result as the same as 3D profile operation where you can control the depth of the created tool path on the part and considered that all non-connected lines are individual lines.
Thank you very much to your reply.
Builder
Builder
Good day,
Thanks Juraj for your input to use the fixed contour  line/points operation, it did solve the problem. What I did first is I used the command extract geometry and then allow the self-intersection option to create the tool path separate on each lines.
Thank you..
