3D cutter compensation / heidenhain or any control
I know it was discussed several times.
How it is status of this functionality?
Do I only have to check mom_contact_status == ON and then output block with:
*mom tool contact point,(should I overide mom pos in check block?)
*contact normal,
*tool axis  ?
It is enough?
proc template post heidenhain:
 #I commented this  if {[info exists mom_output_mode_define] && $mom_output_mode_define != "ROTARY AXES"} {
      # Output contact points
      if { [info exists mom_contact_status] && $mom_contact_status == "ON" } {
         if { [info exists mom_contact_point] } {
            VMOV 3 mom_contact_point mom_pos       ??OK ?
         MOM_force Once NX NY NZ
      } else {
         MOM_suppress Once NX NY NZ
 return 1
   } else {
 return 0
Does anybody have experience with this and use it succesfully?
Is there any weakness with double contact?
thank you
JB
Re: 3D cutter compensation / heidenhain or any control
nobody?
