3d Verify in Nx9 mp3 gone in nx10?
How do I get this back in nx10? I really got used to and liked the new verify.
Dennis Rathi
Creations Unlimited
Re: 3d Verify in Nx9 mp3 gone in nx10?
what 3D verify? As far as I can tell there is no change in NX10.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
NX9 MP3 had only 3d verify which was a crossover between 2d and 3d. Graphics were way better in the 3d version and you could move it around.
Dennis Rathi
Creations Unlimited
I can't see any difference in the 3D verify in NX9.0.3 MP3 vs NX10 (see image below).
The replay results look exactly the same to me.
PhoenxPLM
Dennis Rathi
Creations Unlimited
I don't understand what you're expecting.
The image of the dialog you've posted looks the same to me in my NX9.0.3 MP3 and NX10.
PhoenxPLM
I opened an old file from nx9 in 10 and got similar results with 3d verify. I opened a new file created in 10 and it seems like the graphics display is back to 8.5 style.
Same graphics settings on 9 and 10.
Graphics
Dennis Rathi
Creations Unlimited
With the exception of 2d getting a little more "dirtier" in 9 from previous versions, IMO 3d is still not quite clean enough to eliminate 2d, even though 2d is a static display. #d looks nice on prismatic parts that have large radii.  I still have to use 2d to examine areas with small corners.  I think 3d would be fine if all users programmed were prismatic or large parts but I have found 3d resoultion management to be lacking when verifying 3d mould geometry, especially when I have small corners on large parts.  A typical example is when the displayed cut model is so choppy that I cannot see anything that looks like the small radii I need to verify.  So far I have not been able to determine settings that work well on small and large parts that display well enough to be useful and I do not have the time to switch back and forth between different settings for different parts.
NX 12.0.2
New CAM functionality introduced in NX 9.0.3 becomes available in NX 10.0.1.
I am guessing that you set an ENV to test the new IPW in 9.0.3 MP2, which enhances what you see in 3D verify.
Mark Rief
Retired Siemens
