4 axis machining
best regards.
I am trying to machine a bottle dummi through the 4 axis (A) in a 3 axis machining center (x and z). I tried to do a refining machining, but I could not make the trajectories of the tools follow the shape of the product, I get a warning that only circular surfaces should be selected.
Please, I request your help to machine this container
Re: 4 axis machining
hi,
I use streamline - two flow curves, helical pattern,
tool  axis  - away from line
I did optimize face on this body too because some retracts and engageds were generated.
