4th axis output of A90 and A270 vs A90 and A-90
I have an old post that outputs the 4th axis rotation of A90 and A-90.  I have a newer post that has more functionality so I would like to use it.  The only problem is when posting the same program I get A output of A90 and A270.  This makes the part do a complete rotation and will cause the part to rotate into the table during rotation.
I opened up the post as see a lot of PB_CMD in the new post.
My question is what determines the rotation? I would like it to be shortest path as most of our parts ae run A0, A90, A-90.
I have tried axis limit min max. no change in the output.  Also tried magnitude vs sign.
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
9 REPLIES 9
Re: 4th axis output of A90 and A270 vs A90 and A-90
1) What are the axis limits of the A rotary axis, old vs. new post?
2) Are there any UDEs that might change the axis limits, supported by the old post and not by the new post?
PB V 10.0.3
Axis limits are set to max = 360 min = -360 in both post.  I have tried to set them to 90 and -90 and other values still nothing changes.  its being overiden somewhere else.
neith post use any UDE for rotation.
Damian Forsythe
NX 10.0.3.5
I do see three PB_CMD that all say somthing about rotate.   does anythng look weird in them?
global mom_out_angle_pos
global mom_init_pos
global csys_gohome_flag
global mom_pos
global mom_prev_pos
if ![info exists csys_gohome_flag] {set csys_gohome_flag "FALSE"}
if {$csys_gohome_flag == "TRUE"} {
   MOM_output_literal "G91 G28 Z0"
   PB_CMD_fixture_output_extended
   set mom_out_angle_pos(0) $mom_init_pos(3)
   set mom_pos(3) $mom_init_pos(3)
   MOM_do_template fourth_axis_unclamp
   PB_CMD_fourth_axis_rotate_move
   set mom_prev_pos(3) $mom_init_pos(3)
   MOM_do_template fourth_axis_clamp
   MOM_force once G_adjust H Z
   MOM_do_template first_move_1_do_not_change
   MOM_do_template first_move_2_do_not_change
} else {
global mom_init_pos
global mom_pos
global mom_prev_pos
global mom_sys_auto_clamp
global clamp_rotary_fourth_status
global exists mom_kin_coordinate_system_type
   if { ![info exists mom_sys_auto_clamp] || ![string match "ON" $mom_sys_auto_clamp] } {
return
   if { ![info exists mom_kin_coordinate_system_type] || [string match "MAIN" $mom_kin_coordinate_system_type] } {
return
   PB_CMD_unclamp_fourth_axis
   PB_CMD_clamp_fourth_axis
   set clamp_rotary_fourth_status "CLAMPED"
Damian Forsythe
NX 10.0.3.5
change your Axis Limits to 0-360
sorry
set to -180 to 180
I have already tried that.  it has no affect on the output.axis_limit.JPGaxis_limit-2.JPG
Damian Forsythe
NX 10.0.3.5
I believe that mom_init_pos is available to look ahead a little at the effect of a new kinematic. Do you have head or kinematic switching on this machine?
NX12.02
Windows 10 Pro
ITC Inc.
Or maybe it has something to do with csys type mcs. One of those two. I encountered a siemens written post that used it. At the time it was not documented. Knowing what that is will be the key I think. It has been several years since I worked on that one.
NX12.02
Windows 10 Pro
ITC Inc.
This makes sense.  the post with code i want uses a main, and local from main.  the new post uses main, and local sysy rotaion.
i will try to find the diference
Damian Forsythe
NX 10.0.3.5
