5 Axis Tool Path to Cartesian Coordinates
I have an old 5 axis NC program which I have lost the sample part to. I have a rough idea of how the part looks like, but I would like to make some detailed analyses based on the tool paths so I would like to translate the tool path to Cartesian coordinates. Is NX capable of this? I am open to other possible methods of doing this. Thank you.
1 REPLY 1
Re: 5 Axis Tool Path to Cartesian Coordinates
If you have "old style" CNC programm, without TRAORI,M128 or G43.4 (in this case nc programm use MCS coordinates for XYZ) - you must to remember kinematic of your cnc machine. And dimensions for rotary tables or heads. Then you can recalc mom_pos positions XYZ to cartesian MCS.
I know more better way. Run simulation of your cnc file with 3d material removing and save result as STL...
