5 Axis Under Cut
I am looking for the best way to machine the area circled in the picture. This will be on 5 axis machine using NX12. Looking for the best way to machine what is left after finishing the wall with a 1/2 end mill with .125 corner radius. So i will need to cut the lower part of the wall the radius and some on the floor. I have attached a part file also.1A_02.jpg
Re: 5 Axis Under Cut
Hey @jowens909 ,
I would use a Flowcut Reference toolpath with a Ball Mill
Here is a video of how the material is being removed.
(view in My Videos)
Part file is attached. Done in NX1847.
Let me know if you have any questions.
Cheers,
Alexander
Lead Product Manager - Mold & Die
Thank you @AlexanderFreund ! That worked great. Unfortunately I can't open your prt file. Any way to do that using a variable tool axis? IF possible I could use a tapered end mill.
