Re: 5-axis Machining
attached, just check it please  (If I made this problem or not)
I wait till the end of generating - it took 2 minutes.
In case I set diameter of the ball to 125 mm generating returns error:
In case of proven problem I will report it to Gtac.
@Juraj Loaded the part, calculated and it worked. Part is attached.
Which version are you on?
Lead Product Manager - Mold & Die
hi @AlexanderFreund,
12.0.1
I got the tool path too but generating took 2 minutes what is quite long for a such small prt.
second thing:
When I set ball diameter to 125mm generating was aborted with error mesage:
So what do you suggest?
Please file an IR, because the 125mm Ball was working in my system - besides being a much to big tool for that ;
The performance of Tilt Tool Axis is been worked on.
IR 9094816
btw 125m diameter ball - I meant part diameter, not the tool diameter
Siemens Legend Siemens Legend
Siemens Legend
From GTAC I am learning that the issue you fond in 12.0.1 will be resolved in 12.0.2. the ones testing our EAP versions (EAP12) already have it fixed:
Yours,
Eddy Finaro
NX CAM Product Manager
Siemens PLM
hi,  yes I got this information from GTAC too
is this applicable in Cam Express?
@ReyL Of course :-)
