5axis deburring edges
Hi all,
I need a smaller council. I am shaped part and I need on it fluently in 5 axes deburr sharp edges. My point is that I can change at VARIABLE_CONTOUR point of contact tools. I created a 10mm diameter cutter tip 45. It can somehow change which will affect the cutter? I have enclosed a picture of the model.
Thanks for any advice
Re: 5axis deburring edges
I'm not sure i understood your question but see if the attached solution is good for you
ciao
luciano
That's exactly it.
Thanks very much
May be - another method..
It looks good. Could I ask you for a post how you did it?
I use User Defined method for Drive, Tool Axis and Project Vector. All calculated inside UGOPEN dll (CAM Exit Name is a system variable pointed for this dll).
That it is perfect. So advanced programming'm this and I never used it. Around me it takes some time to knead it, but thank you very much
Thanks!
I still have one question. When I open surgery and user management method and want to open the User parameters, so it tells that there is no environment variables Auto_Chamfer. Needed somewhere to add environment variables?
Of course, you can define Auto_Chamfer system variable, like here:
But - you need dll.
