6Axis postprocessor with two cycle800
I have a problem with configuration 6th axis in my machine. I have the machine with dual axis head (my 5 axis postprocessor) with table (B-Axis).
I want to output from postprocessor two cycle800, where the first cycle800 is for a 4ax XYZB (table) and second cycle800 is for head (5ax XYZCA).
For now, only one value from TC_CARR is read: for TABLE or for HEAD.
TC_CARR:
Everything works independently, but when I want to connect them, it output only for one cycle value :/
In CSE I attached GMe_GetActiveChainName.
Can anyone know how do this?
Best regards,
Jack29
