About excel output the time(hh:mm:ss)
Hi Guys,
I have some question of Excel output: Tool Path Time.
Now the problem is the time always output minutes.
I want output the time is (hh:mm:ss),
My Excel functions is:
=TEXT("${mom_toolpath_time}/864","hh:mm:ss")
But it still the same output.
So... how can I do?
Thanks in advance,
Taco.
Re: About excel output the time(hh:mm:ss)
Guessing here as I have not used excel shop doc templates.
Excel times are decimal fractions of a day.
Try using "time in minutes"/1440 and use excel cell format h:mm:ss
at a guess
${mom_toolpath_time}/1440.0
Hi Agrivas,
I am wrong in the time output is seconds not minutes, sorry!
and I try your answer, but the excel output can't do the operation.
Thanks in advance,
Taco.
Maybe this.
[expr {$mom_operation_time/86400.0}]
If I get a minute I will have a look at Excel shop doc templates
That does not work.
I dont think excel formatting works here
Looking in the shopdoc_excel.tcl it should be possible to do maths on these values.
I am out of ideas on this
I had another go and got it to work.
I put this in the excel sheet and set format to text (not sure if format matters)
'=[clock format [expr {round(${mom_toolpath_time}*60)}] -format %H:%M:%S -gmt 1]
Publish htm and run shop doc and it fails.
Open html template in text editor, search for mom_toolpath_time
Remove the line break from middle of above formula
Works!
Hi Agrivas,
I try your code in excel, but have some trouble:
Html doc code:
The output time is:
It's still wrong!!!
And I don't know where the problem is.
Thanks in advance,
Taco.
Guess ' is the problem.
In Excel you can override format whit ' in the beginning, Excel output Text whatever you write after that character.
I put the leading ' in the excel to stop it raising a formula error
When the file is published to htm it will remove the leading '
It looks like you added it back when removing the line break in the formula.
Hi @CDS and @agrivas,
But when I move ' in HTM, there is nothing in the output.
And attach a video.
(view in My Videos)
Thanks in advance,
Taco.
