Adaptive Milling - Cavity Mill
Good night
Could someone help me in the case below?
How do I insert the "adaptive milling" machining method into the cavity mill strategy?
I use NX 12
Thanks!
3 REPLIES 3
Re: Adaptive Milling - Cavity Mill
you need update you NX to  NX 12.0.2.9
@WendelTrento wrote:
Good night
I use NX 12
Thanks!
Hi @WendelTrento,
since version NX12, there is an Adaptive Milling template included.
It can't be customized into Cavity Mill for many good reasons.
Cheers,
Alexander
Lead Product Manager - Mold & Die
As Alexander stated, you'll need to upgrade to NX 12.0.2
Cavity Mill is a top-down operation
The new Adaptive Milling is a bottom-up operation specific to this methodology of cutting.
Tony Lisle
CAM Application Engineer
Ally PLM Solutions | PROLIM PLM
Excellence in Siemens PLM Software
Tony.Lisle@Prolim.com
Mobile: (513) 325-2993
Office: (513) 984-0480 ext. 123
