Adaptive milling - step up questions
1. question:
Look at this picture bellow.
2 bodies, 2 same operations.
Step up distance is set to 2mm.
Level - single.
On left body I increased draft angle.
On the right body is smaller draft, but there is some.
Why I didnt get 2mm step up on the right body?
2. question:
Why the tool path is not generated to the top of the body?
The last tool path level, top is more than 2mm  bellow the top.
3. question:
What means min cut depth? Because I set it to 2mm.
And as this says,
The tool path is different as I expect.
Thank you for clarifcation
14 REPLIES 14
Re: Adaptive milling - step up questions
@Juraj, I hope you are aware that you are testing a Pre Release version of the software. Would you mind sending me an e-Mail with your questions
Before others ask where to find this, the Bottom Up Cutting Feature for Adaptive Milling will be released at the 22nd January 2019.
We will provide adequate documentation as well as Tutorial videos in time.
Cheers,
Alexander
Lead Product Manager - Mold & Die
@Tony_Lisle from our partner Prolim made a nice Youtube Video about this new functionality. You may want to take a look. Good work :-)
What's new in NX12.0.2 CAM
Hi @AlexanderFreund
Now I remember that I left ENV variable turned on, sorry
No problem at all :-)
You can still use it and give me your feedback if you find something interesting.
How to turn on ENV variable?
Adaptive Milling :
[1]Bottom Up Cutting
[2]Custom Spindle Speed for Helical Engage Moves
How to enable these?
@Aliean
[1] Will be released next january and it is not allowed to share the ENV publically. There are reasons why it is not released yet.
[2] This doesn't need an ENV, since this is available in NX12.0.2 for production usage
Cheers,
Alexander
How can I not open the link?
So if bottom up roughing not available in 12.0.2 yet? I was looking for it but could find it.
It will be released January 2019
