Animation Speed in Tool Path Verify
Hi.
I using NX8.5 Version. Animation speed has been improved in NX8.5 Version.
But We want to slow down the speed of the animation.
Please tell me if there is a way if.
6 REPLIES 6
Re: Animation Speed in Tool Path Verify
this performance behavior is a known topic and I assume you refer to the "Replay" tab.
Less what you can do, but you can check if your graphic card settings has a V-Sync option and try to disable it.
The speed is slower with NX853 MP2
Thomas Schulz
Siemens PLM
Thank.
By V-Sync, animation speed was slightly reduced.
However, we would like to proceed more slowly.
Is there no other way?
Sorry not that I know.
Only NX853 MP2
Thomas Schulz
Siemens PLM
Builder
Builder
Try using TOOL PATH EDIT to verify and you will get a slower display.
MENU:
TOOLS
OPERATION NAVIGATOR
TOOL PATH
EDIT
I have also just found that if you set your motion display option to +/- 100 motions it goes WAY slower when verifying at a speed of 1 because the system has to keep re-calculating the moves to display.
Jake Hardwick
CNC Programmer
Senior Aerospace AMT
Production NX8.5.3.3 Beta testing NX10.0.1.4
