Application Enter Failure
Hi experts,
i have problem after update NX to 12.0.2. After update when open frist part (CAM)  NX show me this window:
NX open gateway. After i click on OK, NX wok normaly.
Does anyone have any idea how to fix it?
Vladimir Jesensky, CAM, TFM Slovakia
Production: (NX 12.0.02 mp05)
Testing:(EAP1872)
Time is money
6 REPLIES 6
Re: Application Enter Failure
Hi Vladimir,
as I replied already to your e-Mail question, I would like to advise you to file your issue to GTAC.
Cheers,
Alexander
Lead Product Manager - Mold & Die
Hello Vladimir
Have you used a custom enviroment? If this is true then start NX out of the box from your startmenu.
if this error still happens this could be a bug.
But i think there is something missing. I had to update several files for our custom enviroment. If you have a special enviroment then make a safety-copy bevor change something.
Siemens added "Multitools" so you should update and add the newest versions.
Have a look in the root folder and compare those files with your custom enviroment files.
C:\...\NX12\MACH\resource\configuration\...
C:\...\NX12\MACH\resource\library\tool\ascii\....
C:\...\NX12\MACH\resource\library\tool\metric\...
C:\...\NX12\MACH\resource\library\tool\english\...
Have also e look in the logfile. In this file is declared where the error happens. Just scroll some lines up to the error message.
Best regards
Production: {NX 12.0.2.9 MP09}
Testing: {NX 1872.0.0.1500 MP--}
Hi.
If I run NX from local computer, everything is ok.If I run it through a BAT file (i have a MACH file on a shared server), I'm throwing the bug. I try to file what to talk to the server and see what it helps.
This is Log:
Successfully loaded dynamic module C:\Siemens\NX 12.0\nxbin\libcamsint.dll
APP_EXITED_APPLICATION_ENVIRONMENT_CALLBACK_ID UG_APP_NOPART.
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX 12.0\mach\application\ug_cam.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX 12.0\ugii\menus\ug_synchronous.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX 12.0\mach\application\ug_cam_view_popup.men
Successfully loaded dynamic module C:\Siemens\NX 12.0\nxbin\libcamsja.dll
Loaded module c:\siemens\nx 12.0\nxbin\libcamsja.dll 7fe95450000 a1e000 dc384805-4557ff25-a437198d-7a184b10-1=libcamsja___1529722296cyp version = 12.0.2.9
Successfully loaded dynamic module C:\Siemens\NX 12.0\nxbin\libtcl.dll
Loaded module c:\windows\system32\logoncli.dll 7fefc950000 30000 88789300-4b7e572c-71378ca6-8fd8aa73-2 version = 6.1.7601.17514
Loaded module c:\windows\system32\samcli.dll 7fefc760000 14000 72203624-462711a8-fdf634bf-8522626e-2 version = 6.1.7601.17514
Loaded module c:\siemens\nx 12.0\nxbin\libtcl.dll 192d0000 19f000 0-0-0-0-0 version = 8.6.2.7
*** EXCEPTION: Error code  1990006 in line 932 of o:\ugnx1202\ip9\src\cams\no\ind\cam_session_definitions.c at Mon Jul 30 06:50:05 2018 Stredoeurópsky čas (letný)
+++ Keyword LIBRARY_MULTITOOL is required.
[ 1] 07FECE6F4A87                                                              (libsyss)
[ 2] 07FECE6F482B                                                              (libsyss)
[ 3] 07FECE6F564A                                                              (libsyss)
[ 4] 07FECE6F5962                                                              (libsyss)
[ 5] 07FECE69FEAE                                                              (libsyss)
[ 6] 07FECE69DE62                                                              (libsyss)
[ 7] 07FE9EA86CC9                                                              (libcams)
[ 8] 07FE9EA88A75                                                              (libcams)
[ 9] 07FE95484903                                                              (libcamsja)
[10] 07FE956B18B3                                                              (libcamsja)
[11] 07FE98AC7E97                                                              (libcamsutilint)
[12] 07FE98FE0FF7                                                              (libcamsint)
[13] 07FE98FD6D75                                                              (libcamsint)
[14] 07FEC54F41C3                                                              (libugui)
[15] 07FEC54F531A                                                              (libugui)
[16] 07FEC54F1838                                                              (libugui)
[17] 07FEC54F62C3                                                              (libugui)
[18] 07FEC51D6A96                                                              (libugui)
[19] 00000068405A                                                              (windowsui)
[20] 00000068461A                                                              (windowsui)
[21] 000000687373                                                              (windowsui)
[22] 07FEC51D79D0                                                              (libugui)
[23] 07FEC54F6027                                                              (libugui)
[24] 07FEC54395A2                                                              (libugui)
[25] 07FEC543944C                                                              (libugui)
[26] 07FEB05D6335                                                              (libuginitint)
[27] 0001400071EF                                                              (ugraf)
[28] 000140003975                                                              (ugraf)
[29] 00014000B562                                                              (ugraf)
[30] 0000774F59CD                                                              (kernel32)
[31] 00007775383D                                                              (ntdll)
>>>> Error code  1990006 caught in file "o:\ugnx1202\ip9\drv\camsja\no\ind\ja_cam_camsession_jam.cxx" at line number 100
>>>> Error code  1990006 caught in file "o:\ugnx1202\ip9\src\ugui\no\ind\ui_app.c" at line number 2379
>>>> Error code  1990006 successfully handled and acknowledged
&MACRO WINDOW RESIZE 1.000000 17.354167 12.520833 -1.000000 -0.721489 1.000000 0.721489
&MACRO WINDOW RESIZE 1.000000 17.354167 12.489583 -1.000000 -0.719688 1.000000 0.719688
APP_EXITED_APPLICATION_ENVIRONMENT_CALLBACK_ID UG_APP_MANUFACTURING.
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX 12.0\ugii\menus\ug_gateway.men
APP_ENTERED_APPLICATION_ENVIRONMENT_CALLBACK_ID UG_APP_GATEWAY.
&MACRO MESSAGE_BOX -2, An error occurred while entering the application UG_APP_MANUFACTURING.  Entering Gateway.
APP_EXITED_APPLICATION_ENVIRONMENT_CALLBACK_ID UG_APP_GATEWAY.
Successfully loaded dynamic module C:\Siemens\NX 12.0\nxbin\libspsdint.dll
Loaded module c:\siemens\nx 12.0\nxbin\libspsdint.dll 7fe95430000 18000 eda7c96e-4817bd69-2d47acb5-638de32e-1=libspsdint___1529722342cyp version = 12.0.2.9
&MACRO FOCUS CHANGE IN 1
&MACRO CURSOR_EVENT 1001 3,1,100,0 ! single_pt, mb1/0+0, , nn
&MACRO CPOS -111.953234530899,-7.71113744597518,132.890360699569
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR <RibbonFileBar->BackStageBar->LeftBackStageGroup->rbn_file_tab_help_cascade.csb> ## !
Successfully loaded dynamic module C:\Siemens\NX 12.0\nxbin\libhelpint.dll
Loaded module c:\siemens\nx 12.0\nxbin\libnxkinematic.dll 7fe94400000 42000 c4c08fea-45e2d246-72af19bd-efc8e9c5-1=libnxkinematic___1529722323cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libmdft.dll 7fe94450000 e7000 5c14715e-4be800ae-829b83a5-d411830f-1=libmdft___1529722114cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libmdphys.dll 7fe94540000 815000 cdf74f21-4a9a6d27-9af7cba-3407140b-1=libmdphys___1529722104cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libassyrni.dll 7fe94d60000 17000 4c2c054f-4e40e031-8031b1bc-c8fbeeed-1=libassyrni___1529722154cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libfmbd.dll 7fe94d80000 23b000 c07b3204-4d0d1646-4af2b79d-747b141b-1=libfmbd___1529722219cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libflat.dll 7fe94fc0000 5b000 bc58130d-44a4185a-e3ec3a6-a0bbbc6c-1=libflat___1529722446cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libsmdint.dll 7fe95020000 281000 280ff482-40a229c0-d3cd9394-ca75e0d0-1=libsmdint___1529722117cyp version = 12.0.2.9
Loaded module c:\siemens\nx 12.0\nxbin\libhelpint.dll 7fe952b0000 17a000 2a69c69a-4b08a19e-84c058a6-87bdf28a-1=libhelpint___1529722250cyp version = 12.0.2.9
&MACRO MENU, 0, UG_LWIN_FILE_EXIT ListingWindowMenuBar !
Thank you.
Testing:(EAP1872)
Time is money
@Bernhard_Swissthak you,
After copying the files in these folders, everything is OK.
Sometimes there was a problem
Testing:(EAP1872)
Time is money
Hello
But watch out... The "tooldatabase.dat" includes your tools... if you copy this your added tools will be gone. For this i wrote you to make a save copy of the files wich you change.
Best regards
It is clear to me when I replace them so I will be fine.
Thank you very much for your advice
Testing:(EAP1872)
Time is money
