Array and List comparing
Hello
Could you please show me how to compare lists or arrays in tcl? (the simplest way)
For example: I have list (or array)  1234 and 2341 - and I want know that both are equal.
thank you very much
5 REPLIES 5
Re: Array and List comparing
Other than searching on Google...
You can compare element-by-element
If order is NOT important, for the list case you can use "lsort" to sort both lists in some consistent order.
For the array case, if order is NOT important, it will be more difficult.
I agree with Ken. If methods which you can google doesn't match your case, I would iterate arrays element-by-element doing comparison the way as I need.
I usually also encapsulate this comparison in separate procedure/method which simply returns result of the comparison.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
@Marek_Pawlus @Ken_A
thank you guys, understand and I will use something.
One more question,
Hope I will describe it well.
Problem:
I want to save list of some elements per operation - so I need more lists and then compare each other.
Is there some way to set new array with some increment or something?
Hi @Juraj ,
If I understand ,you can do with mom_operation_name (with nx you can't have 2 times the same name) :
set myarray($mom_operation_name) [list $mom_... $mom_...]
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
@mkn this is quite interesting and simple
