B live axis turning
Hello everyone,
First of all,sorry if there is a complete guide for a "b live axis turning" for mazak-integrex i300 smooth but I am a little newbie about machining. I am using NX 10,selecting center point of insert for tracking point, providing b axis turning with UDE > insert > b=90 (etc), tool path and simulation shows very good rotation of insert however when I try it on integrex I300, It rotates B axis from spindle pivot,not center of insert radius. (Btw post includes G0 B0.)
I am willing to get a proven guide for b live axis turning, may you guys help me? Thank you.
Re: B live axis turning
B Axis turning is available as a preview in NX 11.0.1 and NX 11.0.2. If you are interested in joing the EAP program to test this, please contact Juergen Becker beckerjuergen@siemens.com.
Mark Rief
Retired Siemens
And (if waiting isn't an option) try using generic motion with a lathe tool. I believe you have to flip an environment variable to have NX allow it:
    UGII_CAM_ALLOW_TURN_TOOL_IN_GMC  1
NX10.03
Windows 7 Pro
Just to be clear on the question. Your posting states "It rotates B axis from spindle pivot,not center of insert radius". That would indicate that you have a problem in the simulation. Not in the programming. Am I correct? Bob Wijers NX CAM Product Management
My impression was that it is about real machine behaviour.
Which makes it similar to my questions:
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/proven-sample-of-l...
...and which confirms my theory, that knowledge how to write working B-live axis turning NC-program, is still a mysterious in many cases...
Marek Pawlus, NCmatic
Production: NX 11.0.2
Development: C#, Tcl/Tk, CSE
In my trials - G43 P1 when using mazatrol tool data will track the tool tip for head/tool. This is set up in parameters (the lengths.) Is that what you are talking about?
NX10.03
Windows 7 Pro
Nevermind - it is non-dynamic. You would have to break the move into a lot of points - that is unusable.
NX10.03
Windows 7 Pro
Sorry for late answer. I forgot my password Smiley Happy I found solution for my problem and If there is anyonr who needs help , I can help.
Hi MDUYMAZ,
I'm new Pre-Sales NX CADCAM based in Singapore.
Could you share with me your B axis Turning solution?
One of my partners need it.
If you could provide a sample part file that will even better
chin.koh@siemens.com
Thanks in advance.
Koh Chin Ann
Siemens Industry Software Pte. Ltd.
          Hi     MDUYMAZ,
Glad to know that you had successfully done the B-Axis live turning. I am trying to learn this NX programming techniqe but i am not there yet. hope you can share the sample NX CAM file for the NX CAM community benefit.
Thank you and apreciate your help,
Best Regards.
