BLK FORM - heidenhain .TCL error
I have some problem with my inner TCL variable.
TNC_UDE.cdl file for blk form is attached into NX (ude named as: Utworz_blok_dla_TNC)
I have already finished all control syntax in postbuilder and still getting error with one variable.. dont know what Iam doing wrong
Values of PB_CMD below:
global mom_czy_byl_block
MOM_do_template start_block
MOM_do_template end_block
Variable is set on global before the procedure set global.
And as you see in my attach picture JPG, when i set two points of blank and after this I tried to post my cam operation - still getting same error can't read "mom_czy_byl_block": no such variable
***** A TCL Error Has Occurred *****
Event Handler: C:\Users\Desktop\Block_Form\test_post\get_balnk.tcl
Event: MOM_start_of_path
Error Info: can't read "mom_czy_byl_block": no such variable while executing
"MOM_start_of_path"
Error Code: NONE
Inside postbuilder, I proper set those of two templates:
BLOCK_TEMPLATE start_block
BLOCK_TEMPLATE end_block
if something has been missed - could You show me what I need to do in next step ???
Engineering >> NX10.0 Performance in the making
4 REPLIES 4
Re: BLK FORM - heidenhain .TCL error
Do you have a procedure for the UDE called MOM_Utworz_blok_dla_TNC?
If you don't have that, the UDE settings are not retrieved from the UDE.
CamExplorer, I'm happy that you're reusing procs from my postprocessor.
But I think, it would be much better to contact author of this post directly.
You will find my name in the header of the *.tcl file.
As I remember, source of missing procedure is encrypted, so you can't read it with notepad.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Ok, understand now.
No I dont have this MOM ude procedure Smiley Sad
Is there any possible way to copy procedure from TNC_UDE.cdl file and paste it to postbuilder in machine control (green label) as Create New Machine Control Event ?
Hey Marek, I get this ude.cdl from my friend - I found this proc in .tcl & .def files. Iam sorry if Iam sharing whith this without prior consultation with You
Problem solved.
Actually I made my own new UDE.cdl for start proc named as: Get_Blank, next I created in postbuilder my new machine control event - same as UDE.cdl with integer (status & points active) in NX. Global variable refers to beginning of post. Blank blocks are working corectly with proper sequencing in header of Start of Program.
New variables are set in MOM_proc global event handler. Added extra PB_CMD customs for getting cutting time to any separated operations from nx via one UDE as folder object>start event.
Post completed and plugged into my own kinematics for machine code simulation.
Thx for help.
Best regards,
