Re: BUG in PostBuilder - On Prepositioning Tool
Problem is fixed in V4.6.3 and later.
If you have no access try following lines
LIB_GE_command_buffer_edit_prepend LIB_CSYS_plane_output_init TRANS_ROT {
     set ::lib_parameter(cycle800,_DIR) 0
} CUSTOM_trans_rot_dir
Hi schauerm, thank you!
I tried, now no more popup error but no value for C and A.
TRAORI
G0 C=$TC_CARR13[$P_TC] A=$TC_CARR14[$P_TC]
Have you tried the NC-Code on the machine?
As I know the controller calculates fron the ROT/AROT the Rotational axis.
This values are stored in the variables $TC_CARR13[$P_TC] and $TC_CARR14[$P_TC].
But it is recommended that the machine have a correct setup.
TC_CARR.def must exist on the machine.
Hi schauerm3!,
No i didn't try the code because i thought it hasn't correct value...
Ok i'll give a try in these days thank you!
Do you where I can check if the file TC_CARR.def exist in the machine?
