Back Chamfer Tool Problem in NX11
Trying to describe solid Carbide Chamfer and back chamfer tool in NX 11. It appears to want an insert and I keep getting various error messages relating to Insert size and hole diameter326 Chamfer Tool.pngTool in questionChamfer Tool Error Message.png
Mike
NX 11.0.2.7
Win 10
Re: Back Chamfer Tool Problem in NX11
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX/Countersinking-the-Back-...
See video in link. I dont think this operation type is for standard milling type tools as shown in the picture you posted.
Your tool looks like there is no offset. In the back countersink tool, the neck is offset from centerline, creating the Neck Diameter when spinning. In the back countersink cycle, the tool is lowered through the hole off center with the spinde off, then moves to center, turns on the spindle, and feeds up.
Mark Rief
Retired Siemens
Hi Mark,
What I am trying to do is use the solid tool to both Chamfer the top then drop in and chamfer the bottom using a circular interpolation. Thinking about it maybe I could describe the tool as a thread mill ? but the tool does not look correct when I try to use standard dialog in NX. It is more like a t Slot Cutter but with angled sides
[cid:image001.png@01D2821E.5BD8A480]
Mike
Mike Restall
CAM Programmer / Process Specialist
Sandvik Coromant
Visiting address:
Wendell
North Carolina
Mobile: 412-443-7707
sandvik.coromant.com
Follow us in social media:
Facebook| YouTube| Twitter| LinkedIn
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
Mike
NX 11.0.2.7
Win 10
Mike
This operation does not support the tool you are trying to use. I use this style tool in a lot of my programming. "Double Angle Chamfer Tool"
Define it as a user defined tool and use a 2d planar profile with tracking points to create your chamfer.
Set the non cutting engage and retract to point and select the center of the hole.
Dennis Rathi
Creations Unlimited
Hi Dennis
How you define, user defined tool values to MRL, to make NX understand.
Tool like this.
NX 11.02 MP9
TC 10.1.7
MRL 3.16
