Barrel 5 axis finishing
My first test with barrel cutter.In NX 10..
https://www.youtube.com/watch?v=qomIrciWzXg
5 REPLIES 5
Re: Barrel 5 axis finishing
Thanks for sharing!
How was the scallop height? I bet it was very smooth.
Mark Rief
Retired Siemens
I`m used 5 mm ...
See my another exemple!
https://www.youtube.com/watch?v=OLyXrXjRpVA
Regards,,
Richard.
Hello
Just from an intrest on 5-axis machining.
Are these tool paths created with some NX-plugin?
Some of our clients are interest to similar type of toolpaths.
So please do share info how these are programmed using NX CAM.
Br Jussi
Builder
Builder
Nice work. Could you post a picture of how you have your tool described?
I would use a barrel cutter. Please see the thread http://community.plm.automation.siemens.com/t5/Discussion-Forum-NX/tool/m-p/347741/highlight/true#M7...
Mark Rief
Retired Siemens
