Big problem with opening part after save NX 1872(1876)
Hi, i have really big problem after save part with another opening this part. Today after cca 12hour work on this part happened to me:
Work work work. Save. postprocesor. save. close. open. and this:
And what do i do now?
Something like this has already happened to me but I revealed that it wasn't possible to open it until I used the automatic tool tilt function in the guiding curve. When I used the automatic tool tilt outside (as a standalone function) it could be opened. But if I used it directly in the surgery it was not possible. My support reported it on IR repport but nothing happens as usual.
I didn't use any guiding curve on this parade. And certainly not any tool tilt.
Does anyone know anything?
Part is here:
https://uloz.to/file/OAksJ7tbJz1A/6-350844-074-000-dbm-ncd1-prt
pass: Sova123
I will new software:-((((((
Thank you
Production: NX 1872
Testing: EAP1899
Time is money
My old name in forum was: Doktorisko
11 REPLIES 11
Betreff: Big problem with opening part after save NX 1872(1876)
I see a bracket ...(programm)... in your path. I think special characters are bad in the path. Have you tried open your file from your desktop?
You can share your part in a .zip in the forum😉
Best regards
Production: {NX 12.0.2.9 MP09}
Testing: {NX 1872.0.0.1500 MP--}
Re: Big problem with opening part after save NX 1872(1876)
I am able to open the prt with a 1899 development version. are you trying to open the EVP saved prt with 1872 or 1899? if 1899 - which version (IP)?
Sorry for the inconvinience,
Eddy
Eddy Finaro
NX CAM Product Manager
Siemens PLM
Hi, bracket is no problom, i use bracket cca 10 years... This is path for server.
Yes i tried part from desktop. Notting has changed. And i tried zip file post on forum, is too bigger.
Production: NX 1872
Testing: EAP1899
Time is money
Hi, i treid open in 1899 build 700. I can´t open in this version.
If you can, bite it and send it to me.
Thank you.
Production: NX 1872
Testing: EAP1899
Time is money
was only able to open it with IP 1000. even IP900 did not work. next EVP - 32 is based on IP 1100 and is planned to be available for download on Aug 19.
not sure how you were able to save a prt with IP700 with data available on IP1000...
Yours,
Eddy Finaro
Siemens PLM
Ok, thank you... :-((
Production: NX 1872
Testing: EAP1899
Time is money
I have gotten the same error with one of my manufacturing parts as well. This is the information I got from my log file. I'm not really sure what to make of it.  log1.JPG
I was forced to use 1872 for one part last week due to an enhancment i needed with guided curve.  i recieved the same error, but was lucky enough to have saved many revisions along the way so i did not loose anything.  We used to move to major releases as they came out.  getting new featutes is a big plus for us, but its become to much work to update all of the individual tool paths, methods, intalled machines ect for how often the new format is changing.  We are probably going to stay with 12 for a while.
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Just wanted to let everyone know that PR 9556482  has been created for this issue.
