Bitmap UDE NX7.5
I am having an issue directing my UDE to pick up a bitmap image that is anywhere other than the standard config directory.
Even if I add a filepath URL to the UDE in postbuilder it will still only pick up .bmp's that are stored in the std congig path.
Due to restrictions where I work I am not able to change this std directory.
So my question is... How do I get the UDE to pick up a .bmp from a filepath of my choice?
Any help is much appreciated.
Cheers,
Don
Re: Bitmap UDE NX7.5
Have you tried to use UGII_BITMAP_PATH?
(This variable defines the directory location for user defined bitmaps)
You should be able to point any folder with this variable.
It could be a problem with the length of the full path, which is restricted for UDE bitmaps.
To test this, you just need to try a shorter path and see if the image is used with a shorter path.
Unfortunately I don't have write access to change this path.
I was hoping the URL within the UDE editor would redirect where it looks for the .bmp, but it doesn't. It always looks in the UGII_BITMAP_PATH directory which is highly frustrating!
Thanks for the tip Stefan.
Just tested your suggestion but still no luck.
The following works for us.
   PARAM siemens_drill_map
      TYPE l
      DEFVAL "$UGII_CAM_USER_DEF_EVENT_DIR/b/ctrl_s840d_CYCLE81.bmp"
Post your example, then you will get better help.
Ok, so here is what I've got thats not working....
UI_HELP "Picture Help" "file://W:/PLM_CAM_DATA/resource/bitmaps/"
PARAM dh_help
     TYPE 1
     DEFVAL "dh_help.bmp"
I think it should be:
PARAM dh_help
     TYPE l
     DEFVAL "W:/PLM_CAM_DATA/resource/bitmaps/dh_help.bmp"
Notice that the type is l (el) like legend, not one like the number.
Cheers Stefan, if I manually change the DEFVAL to my filepath in notepad it works a treat.
For some reason the UDE editor will not allow me to enter a filepath as the default value.
Hopefully this wont have any implications further down the line.
Many thanks for your help.
