Bottom-up Cutting in Adaptive Milling not an option in menu 12.0.2.9
Hi, I am having trouble using the feature Bottom-up Cutting in Adaptive Milling. This option is not showing up in my menu. I have tried adding it through options and menu but still no luck. Anybody know why this is not turning on. This is an OTB menu from contour mill template operation.
3 REPLIES 3
Re: Bottom-up Cutting in Adaptive Milling not an option in menu 12.0.2.9
hi
as far as I know this feature wasnt released in nx1202
I believe juraj is correct.  Bottom up cutting in adaptive milling is available in NX 1847 series.
NX 12.0.2
Hey guys,
yes I can confirm, Bottom Up Cutting for Adaptive Milling has been released in NX1847, so it wasn't available in NX12.0.2.
Cheers,
Alexander
Lead Product Manager - Mold & Die
